Hello everyone, my current sequence files are generating a report for each sequence call inside it, using the new execution method [1]. However, I would like to add the name of each subsequence to the header of each generated report, is this possible? I tried to use the callback ModifyReportHeader and PreUUT following [2], but no success, I got the name "ModifyReportHeader" instead. Also, I think it's important to say that I need to use the option "All Executions Share the Same File Globals" in the sequence file properties.
Could you help me? Thanks a lot!
[1] https://forums.ni.com/t5/Example-Code/TestStand-Generate-a-report-for-each-SubSequence/ta-p/3502029
[2]https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QDNSA2
