NI TestStand
Store in DB Step_Results variable value
Hi, I need to customize the Step_Results table of the TestStand Results.mdb. In the Step_Results table I added a new column. In this column I want to record a variable value when a test is executed. Basically, I need to know when a trest is executed what is the varialble value.
How can I do it?
Thanks a lot
(2,875 Views)
try to give a look to this tutorial
Creating a TestStand Database Schema from Scratch
https://www.ni.com/en/support/documentation/supplemental/07/creating-a-teststand-database-schema-fro...
This tutorial explains the complete customization of an mdb report in TS
Regards
A
(2,865 Views)
