NI TestStand
Still need to mass compile Default values.llb in LV using TS4.2.1?
I'm using TestStand 4.2.1 and LabVIEW 2009. While re-reading (New combination of NI software) "Using LabVIEW and LabWindows/CVI with TestStand I came across this paragraph.
Using a LabVIEW 8.6.x or Later Development System
When you install a version of LabVIEW later than LabVIEW 8.6.x and you
want to use that version of LabVIEW with TestStand, you must complete
the following steps to update TestStand - Default Values 86.llb
to allow the LabVIEW Adapter to retrieve the default parameter values
of the VIs.
1. Create a copy of
TestStand - Default Values 86.llb.
2. Rename the copy TestStand - Default Values xx.llb, where
xx indicates the version of LabVIEW, with out a revision number, you
want to use with TestStand.
3. Mass compile
TestStand - Default Values xx.llb using the
version of LabVIEW you want to use with TestStand.
Do I still have to do this with LabVIEW 2009 and TestStand 4.2.1?
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,854 Views)
Accepted by topic author GovBob
Hi GovBob,
You do not need to do this with LabVIEW 2009 and TestStand 4.2.1. If you navigate to this location: C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.2.1\AdapterSupport\LabVIEW you will see that there is  Default Values 90.llb folder already.
Cheers,
Kelly R.
(3,826 Views)
Thanks for the confirmation.
(3,822 Views)
