Step results not appearing in report
Hello. New to TestStand. I've creted a String Value Test that compares the UUT Serial number using RunState.Root.Locals.UUT.SerialNumber. However, when the report is generated I see no step results. This is only happening with this sequence and not with any of the tutorials. Can anybody point me in the right direction for this. Thanks.
(4,943 Views)
Which process model are you using?  Which version of TestStand are you using?
How are you executing the sequence file?
Do the steps have result recording enabled?
What is your active configuration configured to?
There are a lot of things that could contribute to this.  Do you have a small example that you could post that reproduces the issue?
jigg
CTA, CLA
testeract.com
(4,932 Views)
Here is the sequence file and the LabView vi I'm using.
(4,927 Views)
Accepted by LesKing2014
go to Edit>>Sequence Properties...
Uncheck the checkbox that says: Disable Result Recording For All Steps
Not sure how that got checked but it shouldn't be for MainSequence.
Hope this helps,
jigg
CTA, CLA
testeract.com
(4,921 Views)
Thanks..works.
(4,908 Views)
