08-27-2012 07:55 AM
I want to run step by step in a function which is in a cvi dll. Is it possible ? I have done a cvi debug dll which I used in my TestStand project. But I do not manage to run step by step inside the function in dll.
Solved! Go to Solution.
08-27-2012 09:43 AM
You have to configure the CVI Adapter to execute steps "in an external process of CVI". Then, you can debug the CVI DLL function by stepping through it.
Norbert
08-28-2012 09:26 AM
Another alternative is to run seqedit.exe or your UI as the process to debug from the CVI development environment, then you can either set a breakpoint in your function or on the step in the sequence and then do step into.
Hope this helps,
-Doug
08-28-2012 09:36 AM
Ok, it works. Thanks a lot.
