NI TestStand
Step Status - Numeric limit step
I am using Numeric Limit Test Step.
In the post expression I have a local variable PSVoltStatus to save the Step.Result.Status.
I see that Step.Result.Status has "Passed" status but Locals.PSVoltStatus always stores "Running" status.
How do I save Step.Result.Status status of "Passed"/"Failed"/"Skipped" in Locals.PSVoltStatus variable?
Thanks!!
CLD
(708 Views)
Accepted by topic author lvrat
Hi Ivrat,
thats pretty clear, when looking at the step exection (see help.)
you will see that PostExpression(19) is before StatusExpression(20)
on 19 will get "Running"
as workaround you may place it in user defined PostAction(32).
use the brackets for that like:  { Locals.PSVoltStatus=Step.Result.Status },True
Best Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(684 Views)
