NI TestStand
Station global variable per UUT using a batch process model
I have 4 UUTs which are tested using individual COM ports. I am using 4 Station Global variables to store the 4 Com ports - COM port assignments are in no particular order and vary depending on test station PC.
Example:
S1= Com12
S2= Com14
S3= Com10
S4= Com9
Using a batch process model I want to test all UUTs in parallel - I am trying to figure out what is the best/easiest way to pass S1 for UUT1, S2 for UUT2 and so on!
Any help appreciated.
Thanks & Regards,
Shane.
(3,502 Views)
Accepted by topic author ShaneDonn
The easiest way is to use the Runstate.TestSockets.MyIndex property to index an array.  Each batch socket will get an index (0 to n-1, where n is the number of sockets) when it is created.  Then you can create an array (of strings? I can't tell if you just have strings or need a container) and use the property to index the array.
Josh W.
Certified TestStand Architect
Formerly blue
(3,498 Views)
