NI TestStand
Station Options properties
Hi
I'm trying to get where the Configure -> Station Options -> Execution default values are but no joy. My goal is to change the default value from feature "On Run-Time Error" to "Ignore".
I looked every file on C:\ProgramData\National Instruments\TestStand 2019 (32-bit)\Cfg.
Using 2019 32-bits (19.0.0.170)
(1,312 Views)
https://www.ni.com/docs/de-DE/bundle/teststand/page/configuration-files.html
gives you a pretty comprehensive overwiew about which configuration files are used by TestStand.
Have you checked GeneralEngine.cfg ?
(1,265 Views)
Hello Oli
Yes I checked GeneralEngine.cfg (as suggested by the config files doc), but the only tags that I "found" regarding this feature were BreakOnStepFailure and BreakOnSequenceFailure bellow InteractiveBranchMode tag (which is the option above the On Run-Time Error feature in Station Options)
But, as On Run-Time Error is a select feature, I'm not 100% sure that these tags targets the select option because both BreakOnStepFailure and BreakOnSequenceFailure have a Bool classname. I was expecting something like InteractiveBranchMode tag that has a Num classname and accepts a range of numbers as value (I think these numbers represents the indexes of the select options)
Are you aware of this?
Thanks for the feedback!
(1,234 Views)
Ok, when writing this, I just checked, which cfg file had changed after I did the mod in SeqEdit
Couldn't you just do a diff on the config files before and after the mod to see what has changed on file level?
(1,230 Views)
An alternative and a preferred method is to use the API (StationOptions.RTEOption - NI). Is that not an option?
Anand Jain
NI
(1,215 Views)
