11-17-2017 06:38 AM
We have a Teststand sequence that manage a set of data in a container.
This container should be filled in from a DLL in CVI.
We are able to send CVI a pointer to the container, to create a copy of the container structure in a C structure, fill in the C structure and then memcpy data to TSStand container (through the pointer).
All is OK excepted when one side or the other updates structure (add, remove, move an element): very difficult to check consistency.
I found this thread https://forums.ni.com/t5/NI-TestStand/Best-way-to-pass-an-array-between-TestStand-to-CVI/m-p/1530686... but it said it is an old method (for TS <3.0). Is there a better method to do the job?
11-21-2017 08:02 AM
Hello R1M,
I advice you to consult these 2 papers:
* How To Create a DLL from a LabWindows™/CVI Instrument Driver
* Using Dynamic Link Libraries with NI LabWindows™/CVI™
The easiest way in my opinion to handle struct and match it with container is to add a .fp file (part 4 of the second link).
Hope it will please you.
Bye!
11-28-2017 04:54 AM
it looks interesting.
To be tested in coming days.
10-09-2019 11:09 AM
Is there any update on this topic? We have not found the method to integrate the structure in a .fp.
10-10-2019 06:49 AM
1) What is this warning for? Does it means it is not possible to pass through .fp structures containing structures (struct in C language)?
(see attached picture from help)
2) how should .fp be integrated in the .seq?
11-22-2019 07:35 AM
We can't find the solution: no way to share a structure between CVI and Teststand, with consistency checks (minimum is size, maximum is full list of nodes).
Is there a chance to have a solution, or a consistent example, in a short time?
