05-12-2006 07:25 AM
05-12-2006 04:26 PM
Hi Samuel,
Your test sequencefile, does it contain the override callback PreUUT or are you using the default one in the process model sequence file?
If its callback sequence, what are you doing in it and have you try single stepping through the sequence to see where it hangs.
Regards
Ray Farmer
05-15-2006 02:16 AM
Rax,
I have created an own PreUUT.
05-15-2006 02:26 AM
I have just re-read your original response and I see its the PostUUT not the PreUUT.
But my commets still apply.
What are you doing in the PostUUT.
And have you tried single stepping to find the actually point where the OI hangs.
Regards
Ray Farmer
05-15-2006 02:28 AM
Ray,
I have created my own PreUUT.
In this PreUUT I call the dll for the PopUp windows to enter serial numbers and to select specified UUTs etc...
Yes I have tried to single step through the sequence but then the Problem doesn't occure. (I run it than in the Teststand developer environment) The problem only occures when I use my modified Operator Interface on the second computer. (on my first computer it works without problems)
My suspicion is that my modified simple operator interface makes the problem
what can be the problem? what dlls does the simple operator interface use? Is it possible that on my second computer some standard teststand or Lab Windows CVI dlls are not up to date?
regards samuel
05-15-2006 02:33 AM
Ray
In my PostUUT I call some labWindows dll which create my pass/fail window to show the result to the operator, I call a dll which exits my can bus controller. And I call some IVI drivers to set the measurement devices to a defualt state
regards
samuel
05-15-2006 02:42 AM
Can you identify the differences between the two OI?
If its hanging, maybe you are waiting for some response and therefore haven't return control back to the OI!
Regards
Ray Farmer
05-15-2006 03:01 AM
05-15-2006 04:40 AM
05-15-2006 01:57 PM
Is it possible to supply an example sequencefile which exhibits this problem.
Also what language is your OI built with.
Regards
Ray Farmer
