10-01-2019 12:35 AM
I have a custom PreUUT callback sequence.
I use the SequenceView UI Control (ActiveX) to display the test progress. It shows the test steps correctly, but it stays blank while the PreUUT is running. Is there a way to show the PreUUT steps in the SequenceView?
Solved! Go to Solution.
10-01-2019 10:58 AM
For whatever reason it looks like the engine changes the tracing settings each time a step executes. I tried to put a step at the beginning of setup to turn on tracing but it gets turned off immediately.
As a hack I added the SequenceFilePreStep callback and put RunState.Caller.RunState.Tracing = True in a statement step. I don't like it but it works.
10-07-2019 08:53 PM
It does feel wrong, but I havne't been able to find any other way.
Thank you for a working solution!
