NI TestStand
Setting numbers to specific integer widths in TestStand
I have TestStand 2017 32-bit. I am working with a DLL where arrays of integers are expected to be supplied to the DLL and read back for certain operations. The arrays are of type uint32_t.
I want my TestStand steps to send and receive the data properly. I notice that in TS when you define a number, it's either "default" (which I'm assuming will be 'int' width per system configuration), or you can modify the representation to int64_t or uint64_t.
How can I make my arrays or numbers to be uint32_t? Or does it not matter how I store it in TestStand as long as it's defined by the DLL parameter?
Thank you
(1,946 Views)
Accepted by topic author TestEngineer11
It seems that this questions is addressed here:
https://forums.ni.com/t5/NI-TestStand/how-to-specify-in-TS-unsigned-long-unsigned-short/td-p/701913/...
In summary, TestStand stores all numbers internally by default as 64-bit floating point which is wide enough to cover uint32_t type integers. As long as the module being called specifies this type in its parameters, TestStand should know how to handle it.
(1,885 Views)
