08-23-2019 11:27 AM
Hopefully this question is very easy to answer: I would like to save a binary sequence file as xml or a xml sequence file as binary with the labview API.
Is there a way to access the file format property or is there a function which takes the format as parameter?
Thanks in advance
Michael
Solved! Go to Solution.
08-25-2019 01:08 AM
You can use the FileWritingFormat property:
Hope this helps. Let me know if you have any questions.
08-26-2019 05:49 AM
Many thanks.
I didn't find this property since the sequence file hast to be converted to a PropertyObjectFile by the asPropertyObject method.
You helped me a lot.
Michael
