NI TestStand
Set larger font and fixed size of pop up message
~jiggawax~ wrote:
You can select all the steps at once and change the setting.
You can????  🙂 🙂 🙂 🙂
I will have to investigate.
Unfortunately, I inherited the code, so there was nothing to be done to prevent this.
I will try selecting all.  At least it may reduce the repetitions to 20 or 40 instead of 200.  I will let you know how it went.
Thanks!
Message 11 of 12
(1,188 Views)
Thanks jigg,
Your suggestion to select all works!
Cheers,
RayR
Message 12 of 12
(1,179 Views)
