06-03-2012 07:06 PM
Is there a way to set the Report Options dynamically when the Operator Interface launches? Using CVI 8.5.
For example if user select HTML report then Sequence for Select a Reprot Generator for Producing the Report Body should be selected. Result Filtering to be set to All Results and Include Limits and Measurement checked.
06-04-2012 02:01 PM - edited 06-04-2012 02:06 PM
Hello lvrat,
If you want this to happen each time the Operator Interface launches, you can place a sequence call in "FrontEndCallbacks.seq" to run "Configure Report Options" from the process model. This will essentially call "ModelSupport.seq" which runs modelsupport2.dll. This is exactly what happens when you click Configure->Report Options... from a TestStand Development System.
Note: FrontEndCallbacks.seq runs at the start of the Operator Interface and at the exit of the Operator Interface because it handles Login & Logout. You will need to prevent it from running this "Configure Report Options" sequence call at Logout by setting the Precondition to "!Parameters.logout". Also, If your Login step has a Post Action to "Goto step" -> "<EndGroup>", you must set the Post Action to "Goto Next Step".
Jeff L.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
