I need help to fix a test sequence which is missing failures in the test steps. This post provides one example report of what I see, but there are several other steps that can fail, and the sequence result is still a pass. Some of those other examples the failure is just a measured value falling outside the limit specified in Teststand.
What I am hoping to get is advise on a setting that I have which is incorrect.
I am using TestStand version 3.1, and Labview 7.1 for the individual tests run.
Thanks in advance.
