Are you making modification to the LV operator interface. If so, there is a VI called TestStand - Is Seq File Loaded.vi or you could check the front panel control Sequence File.
If its just that you are using the LV operator interface and are generating Sequences. You could use the override SequenceFileLoad. That executes as the name suggest.
