06-04-2020 02:52 AM
Can I call a Teststand file stored in a folder then add it as a sequence file in already existing set of sequence files.
06-04-2020 11:37 AM
I'm not sure I understand your question. You want to call a TestStand sequence from a sequence file in a different location? And then copy the sequence file to a new location?
06-05-2020 11:23 PM
By moving few content of the sequence out of the already existing sequence file -> external files. Right now there is the steps are inside the settings sequence.This content could be stored external in a sequence file. So that may be I can call this external sequence from the already existing sequence and maybe some more to combine several measurements. Can these external files loaded during runtime with a LabView GUI?
