Sequence call alternative?
Accepted by AldhairGarza
Yes, when an error occured, you terminate the execution means TestStand execute the clean-up of sequences which are still running, then execute PostUUT and PreUUT.
When you are in PreUUT, check the boolean value (we can call it error flag)
if false (default value), display the serial number popup and store it in a station globals property, then execute the Mainsequence
if true (mean that an error occurred), don't display the serial number popup and get the previous serial numbere stored in Station globals
You can also store the error flag in station globals
Hope it helps
Regards
Laurent
Laurent
Message 11 of 16
(821 Views)
Thank you I get that.
One of the goals besides of the 'automation' of the tests, is that
if an Error ocurrs:
1. Log that Error
2. Restart
3. Ignore that error if it is still there.
Do you think is it possible to ignore a specific Error after the restart with the same Logic you are using in your last Answer?
My Channel: https://www.youtube.com/@LV_Lab
Message 12 of 16
(815 Views)
I think you should record all your error code in a array when you are in the PostStepRuntimeError callback.
When you got an error and go to the PostStepRuntimeError callback, check whether this error is in this array
- If not, add the new error code in the array and restart your test
- If yes, ignore the error and continue your test
Regards
Laurent
Message 13 of 16
(810 Views)
Thank you again for your answers.
That sounds like it really could work. And this array must be a StationGlobal variable right?
Message 14 of 16
(806 Views)
Yes
Because you want to reinitialize data at begining of each execution, you can't store data in your sequences. So Station globals seems the good place to me
Regards
Laurent
Message 15 of 16
(804 Views)
That worked pretty well. Thanks a lot. I'm new to Teststand and thought Terminate wasn't something good to do, and since the instructions that were given to me were another ones, Terminate didn't come to my mind.
I appreciate you taking time to help me.
Message 16 of 16
(790 Views)
