06-13-2012 03:44 PM
TestStand 2010 SP1
Sequence.Type and/or Sequence.GetEffectiveType() seems to be returning 0 no matter what sequence I call them from. Anyone know what I could be doing incorrectly?
You can run the attached sequence file and see it.
06-14-2012 11:32 AM
Hi jiggawax,
I have done some testing with your file, and it looks like the GetEffectiveType() method is always returning a 0. I was able to at least read the Type property as a 3 when observing it within the process model. Perhaps these values are not being properly updated in the Sequence object. Are you able to see any other values in any of your sequences?
06-14-2012 11:51 AM
I cannot see any other values.
Interesting observation on my part: The Process Model I had tried it in before was one I copied over from 4.1.1 and had saved as 2010 SP1. However, when I use the default model that ships with 2010 SP1 I get the correct behavior. ODD?? BUT, when I create an empty sequence file from 2010 SP1 and try it I don't get the right values.
I'm with you. I think these values aren't getting updated correctly in the sequence object.
Thanks for the help,
06-14-2012 04:28 PM
Hi jiggawax,
It definitely does seem that this is unexpected behavior. I have made R&D aware of this issue, and it can be monitored with reference #360098.
