Is there a way to resize the sequence name in the Sequence File Hierarchy Call Graph? I have a need to make the sequence names long and it does not fit in the file hierarchy.
There is not a way. The objects that hold the sequence names are a default size. The best way to be able to view the whole name is just to scroll over top of the object.
Jesse S. Applications Engineer National Instruments
