NI TestStand
Seperate reports files for each execution in sequential model
I have multiple (4) UUT adapter one complex Testsystem ( simple: only 1 Multimeter and 1 Relaismatrix).
That means that there are 4 completly different Subsequenecs.
At  moment i am doing this in Batch mode
The MainSeqeunce calls the four the Subsequnces with precondtion Testsocket-Index
by doing this the right Sequence in MainSequnce will be called for the Testsockets.
Now if you want to sycronisies this, it will work Smiley Very Happy, but  nobodyelse can read read your file Smiley Mad!!
So my idea was simple
Use the Sequential mode and let the SubSequence run in different executions.
This works fine but now i am in trouble shooting with the report generation.
I need 4 seperate files not just one.
Any idea Smiley Wink
greetings juergen
(3,017 Views)
If you set the report option "New UUT report file for Each UUT".
Then, If you launch each sequence in new execution using the processmodel it should generate seperate reports. Also set the New Execution so that you dont have to wait for it to complete.
The main sequence you can just run with out an entry point Eg Run MainSequence. and finish when it has launched all the new executions.
Regards
Ray Farmer
Regards
Ray Farmer
(2,950 Views)
