09-13-2005 08:13 AM
09-13-2005 09:11 AM
09-13-2005 10:44 AM
Thanks you, but i don't have LV and VI. I want to use TS with ActiveX
David
09-15-2005 04:39 PM
10-13-2017 12:27 AM - edited 10-13-2017 12:27 AM
Is there any way to send email from Teststand for File Global values ?
10-13-2017 12:57 AM
I did not really understand your question....
You can format your File Globals into a strings. Assembling those strings in a large one, you can send this as an email
10-13-2017 01:30 AM
I need to email a string from Teststand which is stored in FileGlobals.
How can I do it?
10-13-2017 03:14 AM
For sending an email from TestStand you need an external code module (see above)
10-13-2017 05:17 AM
Thanks for reply.
I've another question:
My Teststand will launch a VI when it is executed. If Front panel of that VI was minimized or Closed, then Test stand must pause its execution. I like to have a Customize option [probably in Teststand toolbar] which should again relaunch VI execution from first. Is it possible in Teststand?
Thanks in advance.
10-13-2017 08:52 AM
Please search the forum first. I you can't find what you're looking for,open a new thread decsribing the use case and requirements more precisely, so you can be helped.
