I've just started working with the SemiConductor Test Module. Am I correctly interpreting the following:
- when passing back Boolean results, TestStand only has the ability to interpret TRUE as a passing result - limits cannot be set for Boolean results that would define FALSE as a passing result
- Numeric results must be double sided. I understand that as a developer I could theoretically plug an impossible number into the unused limit to ensure it never fails on that side (e.g. 0 < x < 999999, where the voltage upper range is 10), but I'd have a hard time justifying that to people in some positions at the company who would not understand at first.
- String results cannot be directly evaluated within STM - none of the Evaluation Type seems to support Strings. At best, I can use 'None'.
If I set an Evaluation Type to None, the Export Data To column shows the following error: The expression cannot be empty. TestStand is trying to force me to copy the data somewhere, even if there's otherwise no use for said data?
