I have a number of signal routes using multiple switch cards that I have set up using switch executive. I want to create a scan list that will switch each of my routes in turn each time I see a hardware trigger on the trigger inputs of my switches.
I have looked at some examples in TestStand and can see that if I use the IVI Switch Step using the IVI Switching setting that I can set up a scan list but that seems to be only for one switch card, I have two that I need to route signals to a Digitizer. I can not see a way of using my routes set up using Switch Executive.
I can either use LabView2013 or TestStand 2013 to do this.
Some help would be most appreciated?
Wayne
