10-27-2021 06:35 AM
Hi
We are a few TestStand developers all using the same physical test station at times. We each have a user set up on the system, but it annoys me a bit that every time I use the system somebody has changed the "views" away from the way I prefer them to be (it probably annoys the other guys as well that I change them back 😉 )
Is it possible, somehow, to save the view setup of the environment, i.e. I like to have my steps in the middle on the top, my variables list on the right and my sequence list on the left etc.?
Martin
10-27-2021 07:53 AM
If you use .tsenv then include LocalAppData (see this). Check also this (User-Specific Application Data section). Keep in mind that you have multiple configuration files in TestStand and sometimes you need to use more than one to set up what you like.
