05-04-2012 06:27 PM
When editing in CVI, I often find it useful to copy the contents of 'Find Results' into an edit window so I can edit/parse/filter/sort the information. I would like to be able to do the same thing in the TestStand Sequence Editor. Is a temporary file generated when TestStand Find Results are displayed? If so, where? If not, is there some way to send the results to a text file? Thanks for any help.
Solved! Go to Solution.
05-08-2012 01:21 PM
Hello JoeN,
Unfortunately there are no temporary files generated when TestStand displays those results. Also, there are no API calls that can be made to capture this data. There is some built in sorting functionality in the Find Results window and it is nice to have each search result linked to the sequence, so for that reason this feature was probably not considered. If you want to can make a product suggestion here.
05-09-2012 08:18 PM - edited 05-09-2012 08:20 PM
Jacob,
I went to the TestStand Idea page as you suggested. When I click on the New Idea button, I get "Internet Explorer cannot display the webpage". Might be due to our firewall. Any suggestion? (I tried closing & reopening IE.)
05-10-2012 12:17 PM
Hello JoeN,
I think the link I provided you was wrong.
Try this link.
