09-28-2023 04:17 PM
Hey Ed,
Yes, what you have there looks correct to me. I would expect the Part_TXT field in the PRR to be populated with that expression. Here's an example from my test program with a similar Statement step:
09-29-2023 09:17 AM
09-29-2023 10:07 AM
I don't think TSM 2016 support writing to PRT_TXT of PRR.
09-29-2023 10:14 AM
09-29-2023 10:30 AM
09-29-2023 10:41 AM
It is not about the STDF version, it is about whether the TSM version exposed a way for the user to log data to other fields like PRR.
09-29-2023 10:46 AM
Hi Santhosh,
Thank you for your help. If the STS package (LV, TS, TSM regardless of version) accepts the statement at runtime ... should it work?
Ed
09-29-2023 11:11 AM
I was testing with a newer version (TestStand and TSM 2021). After that note, I installed 2016 to try it there and saw similar behavior to you where the PART_TXT field wasn't being set.
After investigating further, it looks like we discovered that the functionality to set the PART_TXT from MainSequence stopped working in 2016, and we re-added that functionality in TSM 2019. That explains why it was working for me on a newer version. Our apologies for the incorrect documentation in the 2016 version.
So there are two options to set PART_TXT:
