05-21-2020 01:46 PM
Is it possible to run different sequences using the parallel model. Meaning for Socket 0 Seq A is running, Socket 1 Seq B, etc. Ideally what I want to do is use the parallel model to for a 6 socket unit, however I need the ability to change the sequence for each socket as some will run different products. Everything I've seen so far either runs everything from one sequence.
05-22-2020 02:14 AM
Check this: https://zone.ni.com/reference/en-XX/help/370052AA-01/tsexamples/infotopics/dynamic_client/
Alternatively (and easier) create one common sequence with calls to all you specific sequences and set proper precondition for them. I did not tested that but it should work 😉 Something like this:
Remember to deal with proper resource sharing!
05-22-2020 09:14 AM
Thank you, I'll give that a try. The only challenge would be allowing someone to add new sequences in the future. I wouldn't want too many people altering the parallel model.
05-22-2020 09:31 AM
You don't need to alter process model. Create a seq file with calls to all the specific seq calls and run that MAIN seq file with parallel process model.
