05-11-2006 06:02 PM
05-12-2006 12:02 PM
Hi bk1,
I believe the one option that you are forgetting to configure is the batch synchronization option for that sequence call step. Right-click on the step and select Properties. Then select the Synchronization tab and select One Thread Only (First Thread Executes Step, Remaining Thread Skip). This option specifies that only one thread in the batch executes a step. When that thread executes the step, all remaining threads in the batch skip the step. This option should get you up and running!
Hope this helps!
05-15-2006 10:50 AM
