08-02-2021 04:44 AM
Good morning to everyone,
Today I encountered a strange RunTime Error. In Labview I have created a simple sequence which controls a contact in order to transmit signal with the NI USB-6211.
The VI is then inserted in a sequence and integrated in TestStand. During some test on the previous days all worked perfectly, but today while I’m trying to run the same sequence with the same Labview program, I always receive a runtime error with the following characteristics:
The problem is that I have tried to find the cause of this runtime error but I can’t find any clue to solve it. I checked that parameter, files and everything else and all was like the time when all worked correctly.
Moreover, if I run the VI separately, not calling it by TesStand, it runs without problems and as I expected.
If someone have any good idea I am open to everything!
Thank you for the attention and the helps!
Best Regards,
Michele
08-03-2021 06:09 AM
08-05-2021 02:30 AM
Thank you!
I have already checked that link and was not strictly related with my problem. The solution that I found was the kill of the labview and teststand programs and then I have delated and recreated the step for the VI call. That was my solutions.
Best regards and thank you for the help!
Michele
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
