NI TestStand
Run time error running Vision Builder AI inspection from TestStand
Hello Bierzo,
I've the same problem trying to connect to my local target (127.0.0.1), i've a CVS too and i don't have any problem to connect.
What solution did you do?
Message 11 of 14
(1,866 Views)
  Hello Carlius,
   After two years of the problem, i din't find any solution. To solve the problem I exported the VisionBuilder code to Labview, change this one a little, and from teststand call the labview module. Until now is working fine.
   Sorry for no help directly with the question.
   Gonzalo.
Message 12 of 14
(1,842 Views)
Hi Karlius,
Did you follow the steps in this DeveloperZone Article: "Running a Vision Builder AI Inspection from TestStand":
http://zone.ni.com/devzone/cda/tut/p/id/4007
Kristen
Message 13 of 14
(1,827 Views)
HI
I am having the same problem. I have Vision Builder 2012 and TestStand 2012.
Message 14 of 14
(1,307 Views)
