NI TestStand
Run cmd.exe in 32-bit version of TS as if it was run in 64-bit version
I try to call this Bluetooth on/off PowerShell script using the CallExecutable step in TestStand 2020 32-bit. Apparently, it fails in step $bluetooth = $radios | ? { $_.Kind -eq 'Bluetooth' }. However, if I switch to TestStand 2020 64-bit it works like a charm. How can I force the 32-bit version of TestStand to run the CallExecutable step in 64-bit mode? Or maybe how to force cmd.exe/PowerShell.exe in this step to run in 64-bit mode?
Michał Bieńkowski
CLA, CTA
Someone devote his time to help solve your problem? Appreciate it and give kudos. Problem solved? Accept as a solution so that others can find it faster in the future.
Make a contribution to the development of TestStand - vote on TestStand Idea Exchange.
(920 Views)
Accepted by topic author bienieck
My solution is to use bat file. This bat is called using CallExecutable step in TestStand 2020 32-bit. In this bat I call ps1 file BUT using 64 bit PowerShell. Like this: %SystemRoot%\sysnative\WindowsPowerShell\v1.0\PowerShell.exe -NoProfile -ExecutionPolicy Bypass -File %ScriptPath%
Michał Bieńkowski
CLA, CTA
(885 Views)
There is even easier solution, without bat file:
Michał Bieńkowski
CLA, CTA
(835 Views)
