04-14-2010 08:31 PM
I used to right click on a step and select "Show Step In Context Tab". I could then change values etc on the fly. In the latest version of Teststnd I can't find where I can do this. This was very handy for changing values etc during development.
Any help appreciated.
Nigel
Solved! Go to Solution.
04-15-2010 04:51 AM
Are you using TestStand 4.X?
There should be a Tab that you can select which gives you the view that you what.
regards
ray farmer
04-15-2010 09:26 AM
There is a context menu "Show Step in Variables" that does exactly the same thing. It's called a Variables View rather than a Context View in TestStand 4.0 and higher.
Hope this helps,
-Doug
04-15-2010 11:22 PM
Thanks for the replies; the show step in variables does it...
Thanks again this saves a fair amount of time during testing etc.
