NI TestStand
Retrieve Teststand-Logged Analog Waveform from SQL-Database and display data in LabVIEW VI
Hi all,
I'm struggling while retrieving Analog Waveform Data from a SQL DB.
Does anyone know how to get the binary data (readable and correct) out of the DATA-Column via Labview VI?
- In Teststand, logging Analog Waveform  to SQL-DB works well => Result processing
  The data gets stored in the table "PROP_ANALOGWAVEFORM" / column "DATA"
- I can read the data correct with the NI Database Viewer and display it there
Environment:
Teststand 2023Q4
LabVIEW 2024 F1 / DB Toolkit
Any help is highly appreciated! 🙂
Michel
Message 1 of 1
(436 Views)
