06-13-2019 06:48 AM
is there any way to record the result of step inside the sub sequence, when the sub sequence result recording options is disabled.
Because I have a group of test to be performed inside a sub sequence and I dont want the sub sequence information in my test report.
Can we add some expression in Result filtering?
06-13-2019 01:37 PM
Click the step you want to turn recording on for
Click the properties tab in your step settings pane
Click the Run Options in the list box
For Result Recording Option choose Enabled (override sequence settings)
06-16-2019 02:30 AM
I tried the same, But its not updating in Report,using ASCII Test Format Report
I m following the below step, please let me if required any corrections
1. I called the sub sequence in main sequence and disabled the report recording option in that
2. Set the result recording option "Enabled (override sequence settings)" for pass fail test inside that sub sequence.
Attaching the sequence file below.
06-17-2019 10:03 AM
I've fixed it. You have to enable recording for the sequence call but disable recording on the sequence itself. Then override that on a per step basis.
Hope this helps,
06-17-2019 10:33 AM
Now Sequence call in the main sequence also displaying in report
06-17-2019 11:27 AM
The way that result collection works in TestStand is that each sequence contains a Locals.ResultList. Each time a step executes it places a "container" inside of that result list. The result list is then passed back to the caller until eventually MainSequence passes it's result list to the process model to be parsed. The process model then hands that result list off to the model plugins for parsing and report generation. So each model plugin will recurse through the result list tree and pull out any step/result that it thinks should be on the report (which by default is all of them). The problem is that you cannot have subsequence results and not have the parent container (in this case the sequence call) unless you are able to flatten it out and remove the parent container before injecting it into the caller's result list.
I'm attaching one way of maybe fixing your issue. Give it some thought.
06-18-2019 07:47 AM
Thank you Very much for the support!
I understood your sequence. In my case I have CAN response ,which is having multiple parameters to be compared . I want to make these Parameter comparison inside a single sub sequence to avoid the error ,if the user rearrange the step in the main sequence.
I think i found one method to filter it from the Report. I m using NI_SimpeTextRerpot_LabVIEW. So that i can modify the VI inside that and filter the report by checking the TS.steptype in "ProcessOneResult.vi" as shown below.
