Reseting Flie Global Vaiables
Is there a way to reset all File Global variables to their default values in Teststand without having to modify them one by one?
(741 Views)
Default values are here: https://zone.ni.com/reference/en-XX/help/370052AA-01/tsapiref/reftopics/sequencefile_fileglobalsdefa...
You should be able to replace your current globals with those from this prop.
Michał Bieńkowski
CLA, CTA
Someone devote his time to help solve your problem? Appreciate it and give kudos. Problem solved? Accept as a solution so that others can find it faster in the future.
Make a contribution to the development of TestStand - vote on TestStand Idea Exchange.
(715 Views)
You may need to use Clone() method.
Michał Bieńkowski
CLA, CTA
(707 Views)
