NI TestStand
Requirements Gateway TS-Intermidiate File
I would like to know if there is change to modify the Intermidiate File Genenerator for TestStand?
or is there a way to implement user defined generators?
Juergen
--Signature--
NIWeek 2017: Standardized HIL Test Automation With TestStand
NIWeek 2016: Capturing ATE Requirements With Requirements Gateway
Feedback or kudos are welcome
Message 1 of 10
(3,126 Views)
Hi Juergen,
We currently do not expose a method for creating your own convert tool (generator).  However, this is something we would like to add in the future.  Is there a specific limitation of the existing TestStand convert tool you are struggling with?
Al B.
Staff Software Engineer - TestStand
CTA/CLD
Message 2 of 10
(3,116 Views)
Hi Al,
often i am focused with this question:" Are there same limits in specification and testprogramm ?"
With NIRG i will see change to answer this question.
I just want to reduce it to  NumericLimitTest and our own Testsytem's StepType http://sine.ni.com/cs/app/doc/p/id/cs-11443.
To realize this it is necessary to have limit information in the intermidiate file.
At the moment it is impossible to give answer, because information were not provieded by the generator
Juergen
--Signature--
Message 3 of 10
(3,110 Views)
Hi Juergen,
Thanks for clarifying. I will create a feature request to include limits in the intermediate file for sequences.  In the meantime, a couple possible alternatives are:
  • Instead of hard coding your limits in TestStand, create an excel or text document which contains the limits, and use the property loader or other means to populate your test sequences with these properties.  This way, Requirements Gateway will have access to the limits from your limits file.
  • Limit information is in the test report intermediate file, so use this as proof that the limits are accurate
Al B.
CTA/CLD
Message 4 of 10
(3,099 Views)
Hi Al,
I have decided to try it with the report.
But combining ID and Limit in the XML Report will fail.
I opended a new thread to discuss:
http://forums.ni.com/t5/NI-TestStand/Requirements-Gateway-Identifier-Format/td-p/2338498
btw i have looked on the NI-RG code. It seems most stuff is done in ot-scripts.
I suppose TeststandSequenceFile generator is done in ot, too. But this script is complied.
i have no change to look inside. Is there a reason why the compiled one is shipped while the
Microsoft one's like Word,Excel and Access are non complied ?
Juergen
--Signature--
Message 5 of 10
(3,012 Views)
The word, Excel, and Access converters call microsoft APIs which are public, which is why the source code is provided.  The NI converters use internal APIs that we unfortunately cannot make available externally.
Al B.
CTA/CLD
Message 6 of 10
(2,953 Views)
Hi Al,
if private API functions were used it is clear that it is not avialable. But if i take a look at TS's intermidiate file i am quite sure that a user with basic knowlege about Teststand API or advanced training skill is able to create such file with the public API.
It would be nice to see in future releases a possibility to place OT-Scripts for public teststand API.
Juergen
--Signature--
Message 7 of 10
(2,948 Views)
I will note this feedback to the development team
Al B.
CTA/CLD
Message 8 of 10
(2,931 Views)
Thank you!
--Signature--
Message 9 of 10
(2,914 Views)
Accepted by j_dodek
Hi Al,
last few days i have spent some time on creating my own intermidiate file generator.
The biggest challange was implementing the generator without any documentation into NI-RG.
Now I am proud to say that is possible just by using ot-scripting combined with com-interop.
With this generator i am able to compare all testspecifications limits  with the programmed ones in the
the TestStand sequencefile and make a statement that they are covered and equal, too.
Juergen
--Signature--
Message 10 of 10
(2,682 Views)
