From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
Report the results of a subsequence
My problem is the subsequences are not logged into the report.
What can I do?  (The option "Record Results"[Run Options] is marked.)
(3,022 Views)
Check that the step in caller sequence that invokes your sub-sequence has the record result enabled. To do this highlight the step, right mouse click and set "Properties..". In the Run Option ensure the Record result checkbox is enabled.
Regards
Ray Farmer
Regards
Ray Farmer
(3,018 Views)
The problem was the checkbox was already enabled.
But I found my problem, I did some changes in the report_html.seq which causes this problem.
Now everything is ok.
thx
(3,016 Views)
Hi giese_m,
Glad you have been able to sort the problem yourselve.
Just a couple of small comments to your initial query,
1) additional comment to the fact that your step had the record result property enabled would have helped.
2) the fact that you had modified the report generation sequence file was a vitial bit of information missing from your query.
Regards
Ray Farmer
Regards
Ray Farmer
(3,013 Views)
