NI TestStand
Report multiple failures with TestStand reporting
I'm pretty new to TestStand so please bear with me. I'm using LabView to test a connector on a digital interface board. So I'm reading and writing dig. signals on say 15 pins in a test. I'm using TestStand to run my VI's. When a test fails TestStand seems to only report one measurement at a time. I want all of the pins that failed to show up in the TestStand report in a format like :
InputPin:A1 OutputPin:B1 Expected:0 Read:1
InputPin:a2 outpuPIn:b1 expected:1 read:0
I tried using the ReportText section of the TestData Cluster but I couldn't format it properly. All of the data sort of runs into each other like this
input:a1 output:b1 expect:0 read:1 input:a2 output:b2
the carriage returns I tried to put in were i
gnored.
Does anybody know how I can report a lot of failures in one report. I hope I explained properly.Thanks
(3,534 Views)
Find attached an example using the MultipleNumericLimitTest step type.
All it does is use the array found in Locals call Digital as the DataSource for the Limits. You can check this by selecting the step and doing a right mouse click - select Edit Limits. Then select the Data source Tab. I have add 16 Measurements, one for each of the array elements.
This will give a you a result of each element of the array in the report for that step. But by default it will look like:
Measurement[0] (Measurement 0):
Limits:
Low: 0b1
Comparison Type: EQ (==)
Data: 0b0
Status: Failed
To get the format you require will mean modifying the report sequence file.
Hope this helps a bit
Regards
Ray
Farmer
Regards
Ray Farmer
(3,534 Views)
Thanks Ray, but one more question. I'm testing a connector that consists of say, 10 pins. If one or more of them fail I want this reported. How can I get the pin names to appear in the report so the operator knows which pins are failing?
Thanks again
Mike
(3,534 Views)
Yes you can name each measurement in the Edit Limits dialog. I have modified the example sequence and each measurement has the name 'Test Pin x' now in the report you would see :
Measurement[0] (Test Pin 1):
Limits:
Low: 0b1
Data: 0b0
Status: Failed
You will see that the prevoius displayed text was 'Measurement 0'has been replaced by the new text supplied.
Regards
Ray Farmer
Regards
Ray Farmer
(3,534 Views)
Thanks Ray,
What I previously started doing, because my test was originally written as a pass/fail test, is testing all of the pins on the connector, capturing all of the failures in arrays, formatting the text, and sending it in the report text of the test data cluster. I haven't worked with these multiple numeric tests so this is a big help.
Mike
(3,534 Views)
