NI TestStand
Report generation delay - Batch Model
I am using the standard TestStand User Interface to deploy my sequence, using the batch model.
I have been experiencing intermittent long delays when generating reports at the end of a batch test - see attached screenshot.  There is no report generation delay if I run using Sequential model.  The main sequence I am using is a "Dummy", and consists of only a couple of steps.
Has anyone experienced this?
Dan
Dan
CLD
(2,126 Views)
Hi Dan,
How long is your delay and how are you timing this delay?
What type of file are you producing for your report? What are your report configuration settings?
Where is the location of the report? Is it on a network drive or is it on the same disk?
(2,081 Views)
