01-26-2017 03:10 PM
I'm trying to change the way my teststand report is displaying results. I must be donig something incorrect because when I run a test I am trying to output data from LabView and compare it in Teststand with a value from the library. Even though the value passes it says it failed, and the numeric value is not showing up in the report in the correct location. I have included three screenshots to show in a better way what I am trying to explain. Can someone please let me know what I'm doing wrong?
Jon
01-26-2017 03:42 PM
I believe I've figured it out by changing the output of the module from local.compareSBP to Step.Result.Numeric in teststand
