NI TestStand
Remove Subsequence Headings From XML Report
I've modified the default stylesheet to remove a lot of the fluff added in the test report. However, I'm stuck trying to remove the subsequence headings from the report. Can anyone with stylesheet experience give me some advice?
I can't modify TestStand reporting at all, only the stylesheet.
I've attached a picure which hopefully should help expain the problem.
-Jeremy
(4,166 Views)
Hello Jeremy,
This white paper discusses how to exclude results from reports using filtering. I imagine you could create a filter based on the step values.
(4,146 Views)
