05-18-2009 02:31 PM
05-19-2009 01:37 AM
Hi David,
If its the currently executing Step properties you are after to use in the Code Module, then use
ThisContext.RunState.Step
The error message you are seeing should identify the Property you are trying to access is this correct item?
Ray Farmer
05-27-2009 06:29 PM
Hi Ray,
I get an error when trying to access ThisContext.RunState.Step, using "set property" wired with sequence context in my vi. I can put a breakpoint in the sequence, and browse the variables tree, but do not see the property "ThisContext.RunState.Step". I do see ThisContext.RunState.Main.Step, but that references the step in the calling sequence. Is there perhaps another property somewhere?
Dave
05-27-2009 06:38 PM
I think I may have a little bit of clue what is going on. I am trying to write data back to teststand from a vi, which is a queued state machine, executing waiting for commands while teststand is executing. It is launched in the parent sequence, with the sequence context of the parent sequence passed in. This is the sequence context which is referenced in the code of labview vi. So when I reference this sequence context, while executing a step that is in a subsequence, sequence context might still reflect the parent sequence, and not the subsequence? If so, how do I use the parent sequences "sequence context" to get at my the currently executing subsequences context? Or is there a property which always holds the currently executing "step" context, no matter where you are querying from?
Dave
05-29-2009 01:48 AM
Hi David,
Checkout the following example, this may help you.
http://zone.ni.com/devzone/cda/epd/p/id/5838
Ray Farmer
05-29-2009 02:29 PM - edited 05-29-2009 02:31 PM
Hi Dave,
After speaking with a co-worker of mine, we came up with a way to get the current sequence context in your code module. Basically, we have the sequence context from when the code module was called initially. Then you can use the sequence context to get the execution, which you can use to get the current thread. From that, you can get the sequence context from that thread and have access to whatever you need from there. We created an example program that has a sequence that launches a VI that just runs a while loop and shows the current sequence name. Here is a screenshot of the code module:
05-29-2009 02:39 PM
Ray,
This is very interesting and pertinent to a couple of our projects. Unfortunately our company blocks ftp access, so I can't get at the example file linked to in this article. Can you possible post that to this forum? I'd appreciate it. thanks
05-29-2009 03:05 PM
Eric,
Your solution works great. I knew there had to be a way, I just couldn't find the trick. Thanks
Dave
