NI TestStand
Property Loader Step Limits => where to find in RunState?
Hi!
I use the Property Loader to import all Step Limits in all sequences. So in the dialog of the property loader step the properties list to import contains entries like "Step.Limits.Low".
Now I want to overwrite the imported values during runtime in special cases, but I don't find where the imported values are stored in RunState.xxx
Does anyone know where the imported values are stored???
Thanks in advance
Steffen
(3,186 Views)
It will be stored in the respective step variables.
You can use this (step name is "Numeric Limit Step" in this example)
RunState.Sequence.Main["Numeric Limit Test"].Limits.Low
(3,179 Views)
