NI TestStand
Process Model Cleanup group doesn't run on Termination?
I'm using TestStand 1.0.3. I have a custom process model. I would like to
perform clean-up tasks in the process model if and when a user terminates
the execution of a sequence which uses this process model. However, it
appears that only the Cleanup step group of the client sequence get executed
upon a termination. The process model's Cleanup step group apparently only
gets called when execution ends "normally" (no termination). Does this
sound correct? How do I implement termination handling at the process model
level? I don't want to have to add code to (potentially dozens of) client
sequences.
Bob Rafuse
Etec Inc.
(4,096 Views)
to
executed
only
model
> sequences.
Oops. Never mind. I thought "Allow Break While Terminating" was set, but
it wasn't. My bad.
Bob Rafuse.
(4,096 Views)
