03-06-2008 02:14 AM
Solved! Go to Solution.
03-12-2008 10:26 AM
03-13-2008 01:21 AM
03-13-2008 09:44 AM
i have made a new connection via odbc sql-server. I mark "save long querys" and watch the log file after the timeout occured. It says: select * from "maintable", but my maintable is too big! Why teststand select all data from the maintable to make a connection? Can i turn it off?
thanks schwede
11-11-2008 04:41 AM
the solution ist to use: select TOP 0 * ... then the table will be loaded empty.
greetings schwede
