Hi
Using TestStand 2.0
I am using a ticket printer to show test failures.
I have added a print line into the process sequence and formated the header with no problems, changing reportgen_txt.
The "report options" are set to ASCii format and to exclude Passed/Done/Skipped results.
The ticket prints nicely. But it shows every sequence call with a:-
Begin Sequence: 1
(C:\Sequence Name)
End Sequence: 1
I have 67 sequences, this is a lot of wasted paper.
Does anyone know of an expresion that I can add into "Report Options" to remove this sequence info?
Or is there another way of doing what I want?
Hugh
