03-20-2014 05:46 AM
Hi all
the expression Field for a step does not allow use of If else statements
should I take it as "limited" feature of teststand & use the Statement-step or am I misled!
03-20-2014 05:52 AM
I think If else cant be used in "expression"
may be I have to use the flow control
03-20-2014 06:23 AM
What exactly are you trying to do? If you are trying to set a value, then it can be done.
locals.num = locals.bool? TrueValue:FalseValue
03-20-2014 06:31 AM
I wanted to use the If else condition statements
but now I am able to do the same with "?:"
03-20-2014 06:50 AM
It's true that expression allow only "a boolean select".
What is the use case for more complicated selections with more than two options?
Why is it beneficial to implement this as a step component (that means: obfuscating options) instead of displaying the selection in an obvious, readable way as multiple steps?
Norbert
