08-26-2020 08:28 AM
I have been using ActiveX Excel(16.0) in teststand(2016 SP1) for several years. Except that for a few days it no longer works.
There is an error message:
"Create New Object" in automation call failed (see attached file)
I did the test on another PC it works perfectly
Do you have any idea?
thank you
08-26-2020 08:34 AM
08-26-2020 08:44 AM
Yes, the config is correct?
08-26-2020 09:56 AM - edited 08-26-2020 09:57 AM
Not sure what you mean by "config" but, what it is sure is that if the same sequence works in other PC, must be something in you Excel installation or TestStand configuration/installation.
I would try to register again the ActiveX, re-install Excel, import all cfg file from the PC where it works...
08-26-2020 10:22 AM
I was talking about the "adapter activeX" config in Teststand.
The configs are identical on the different PCs. On the PC in question, it worked correctly a few days ago
08-27-2020 08:12 AM
I realized that it no longer works with Labwindows CVI.
After reinstalling Office365, the issue is resolved.
Thanks for your help
